BFL13
Aug 27, 2018Explorer II
Straylight wrote:
Could be that you have a phantom draw (maybe your fridge?), could be that your coffee maker is higher wattage than you have been led to believe (especially during startup), but it also could be this thing I used to hear but now can find no evidence for: That some inverters and inverter generators really don't like appliances that generate heat in the same way a toaster or electric heater does. Something about the inverter seeing it as a short? Don't quote me on it.
Yes, AFAIK, OEM set-ups in new rigs like that are for a res fridge. They can do that. Once you try to do something else, you get in trouble. Could be the wiring is too thin for anything more than what the fridge pulls, or for several other reasons as given in this thread.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
