CA_Traveler
Feb 20, 2021Explorer III
Darklock wrote:Lately all of TX has snow and ice. SW AZ is still in high 30's/40 early morining, about 70 daytime.
Our plans are for spending a month or two next winter in south Texas and Arizona, trying to stay where it is warm enough not to need furnace. If nights are cold and we need to run furnace, we do have a Honda generator for use if needed, but since a lot of our days are spent out roaming we need something passive for general use that also charges while on the road. I always thought that while towing, the vehicle would keep the charge up, but recently learned that this not the case. Still learning about the whole camper thing.
If your tow vehicle has a charge line and it's working it will charge the battery. Or you can add one. A 4 pin plug is for turn signal, lights, ground - no charging. One more wire is needed for charging.
