JimK-NY
Feb 20, 2021Explorer II
You need to do an energy audit. If you are truly just considering a propane refrigerator and some LED lights, you should be fine. Don't forget other possible uses. The furnace is a real energy hog but you should be fine for occasional use in moderate temps. You will also be using a water pump. Again, not much but it adds up. What about a TV or charging a laptop? Those are big energy hogs. Charging cellphones, camera batteries? A 12v fan in hot weather?
