bkf's avatar
bkf
Will bad house batteries cause 120v shoreline power issues?
Hi all! I've got a ~2013 Class A that we've full- or half-timed in for the past almost-6 years. It's got 4 Group 24 (EDIT: actually Group GC2 6-Volt) flooded batteries, with a Magnum charger/inverter. We're almost 40' so almost never boondock except for an occasional night here and there in a WalMart parking lot while we're getting from point A to point B :) I've got the Flow-Rite system to keep the batteries topped up with distilled water.
The batteries definitely don't hold a charge like they used to, but it's never been a problem, as we don't really use them much. But…
During the past 2 weeks, things seem to have gone downhill, fast. The batteries are 6 years old, so my hunch is that they just need to be replaced, BUT… I want to make sure there's not another problem going on. We're on 30amp shore power, but our rig can handle 50amps.
Symptoms in the past 2 weeks include:
  • 12v lighting goes pretty dim, then will occasionally kick on to full brightness.
  • The little Magnum control panel inside the coach turns on the red light, but often the screen says something about missing AC power, which is odd to me.
  • Some of my 120v outlets will go through periods where they lose power for about a half-second, every few minutes. This power cycling will happen for hours, then will just stop and everything'll be fine. Oddly, this isn't all outlets. The clock on the microwave doesn't reset, but my cable modem (we're in one park for the next ~year; atypical for us) will reset every few minutes, and my computer charger will blink off, on a separate outlet).
If it was just the 12v lights going dim, I'd be much more comfortable replacing the batteries. But with the 120v AC power acting up, I'm worried the dim 12v might be a symptom and not a cause. We'll be plugged in for the next year, so I don't want to drop a ton of money on new house batteries only to discover I didn't need them and should have spent the money elsewhere.
I'd love advice or experiences from anybody who knows more about batteries and inverters/converters/chargers! Thanks!
