time2roll
Sep 07, 2018Nomad
Amps is not a huge issue when plugged in for an extended period.
However battery voltage is critical and the first indication something is wrong. Anything much below the float setting or about 13.2 volts is failing when plugged in.
Even a 10+ amp charger needs to get on those batteries asap.
