MrWizard
Aug 28, 2018Moderator
from the description
it sunds like your magnum inverter/charger is failing
it has 120v power pass thru, so those intermittent circuits could be outlets connected to the magnum
i think there is a power off, battery disconnect , reset sequence
it should be listed in your manual
i would try that, then i would charge the batteries with a stand alone battery charger, be fore replacing them
