- gkainzExplorermine won't
- ItsyRVExplorer
groundhogy wrote:
I have a low profile a/c, but the only available unit is the regular coleman
Are you looking for In-Stock Off-the-Shelf today or within the 10 day window? Buddy ordered one over this weekend and his email yesterday said delivery next week Friday. - ksg5000ExplorerGenerator cost more than an RV AC unit ... I would first ask if 13.5 AC can be started with your current generator. Just my 02.
- ReneeGExplorerIt won't unless you have one of the new Easy Start modules on your AC. It's the initial draw of power that's the killer on the generator.
- SeonExplorer II
groundhogy wrote:
... thats not the answer i was looking for...
I think it will, but only if you parallel connect it with another generator.
Is that the answer you are looking for? ;). - jdc1Explorer III like my AC too much to burn it up using my Honda eu2000i.
- 2oldmanExplorer II
jdc1 wrote:
I could say that about my eu2000.
I like my AC too much to burn it up using my Honda eu2000i. - FLY_4_FUNExplorerI have a 15k a/c and it will start and run it for a few seconds (honda EU2000i) then go into overload. Thats with genset all warmed up, not in eco mode....
Even if yours does run it, I doubt it will last the first cooling cycle before it kicks off. - wa8yxmExplorer IIIThis is the kind of question that is tough to answer because
Sometimes they do, Sometimes they don't.
When I did my first upgrade from 13.5 to 15 KBTU turns out the running current was identical.. Starting i'm not so sure of (I think it took a bit more) but with a soft start they sucked about the same. BUT my 2nd one takes 1/2 amp (About 50 watts) more and with a Honda 2000.. you may well not have the spare half amp (might be 2 or 3 amps starting) plus it starts much "Harder".
So.. you won't know till you try. - LwiddisExplorer II“... thats not the answer i was looking for...”
But it’s an honest answer.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
