outwestbound's avatar
outwestbound
Will Honda 2000 supply MSH 3012's charger?
Hello. Looking to power my fifth wheel travel trailer for off grid boondocking using combo seeking a maximum reliance on solar and a minimum on generator. My goal is to carry, due to size and weight, the smallest generator necessary to bring an 800 amp hour AGM battery bank up to 100%.
Magnum MSH 3012 has a 125A charger and the max charge rate is set to 80%; so max 100vdc I guess.
Magnum's manual says 18AAC input current is needed to operate at it's continuous rated output.
Honda 2000's max of 2.0kVA (16.67A) and continuous of 1.6kVA (13.3A) seems insufficient.
I don't understand if only 13.3A from the Honda will NEVER allow the Magnum to charge the batts to 100% OR whether the lower input to the Magnum will just take longer. (????)
If it just takes longer, I wonder how much longer. For example, if I'm down 150AH on the bank and have 3 rainy days with no meaningful contribution from solar, and crank up the Honda 2000, how effective/ practical will this be?
I'm aware that my max charge 80% setting limits the charge to a max of 100vdc, but have no idea what under powering the charger, if at all, will do.
I hope this makes sense. Thanks
