- westendExplorerYou're very welcome. Glad it turned out good for you.
The Todd power supplies are posted about here, mostly not working correctly. Good choice on upgrading. - daheada11Explorerall done works great ,thanks again for the info.i put in a reciprocal with no switch .your right this unit is protected so why give it another place to possibly fail at some point.thanks for the advise.
- westendExplorer
daheada11 wrote:
Your call. A switched receptacle with indicator lamp could be a good choice. It does add one more point to fail and the converter circuit is already protected and switched by the circuit breaker. I think a lot of converters are using just a wire set with plug, now. If you support the wire for the converter close to the receptacle, there shouldn't be much worry about it coming loose.
should i also install a switch to shut it off at or not necessary/over kill - daheada11Explorershould i also install a switch to shut it off at or not necessary/over kill
- westendExplorerI would suggest to install new NMMB (Romex) and install a receptacle. Since you don't know the existing wire size, we don't either. A new piece of Romex is inexpensive, and if you install it yourself, you'll know it's right.
- daheada11Explorerfinally purchased a new progressive dynamics 9260 converter.found i have one problem .the old one was hard wired ,the new one comes with a plug on it ,i dont want to mess with the warranty by cutting the plug. looks like who ever built this RV cut the plug end off of the old unit and hard wired it directly to the breaker box.should i do the same thing except with romex wire and put a reciprocal on the other end so i could just plug in. reason of changing the wire ,is because the old unit was a 30amp this new unit is a 60 amp .any suggestions or different ideas would be a great help.or can i use the existing wire that was hard wire and cut the end and put a reciprocal.would it be thick enough thank you mike
- daheada11ExplorerTHANK YOU all for the advise, first thing monday morning i will be on the hunt for a new PD converter.my tt has been parked for a while due to this problem.we love to camp and our tt has always been plugged in never had any issues,until this and a small leak in frt behind one of the lights.is it a bad thing to have it plugged in all the time.i have asked in the past and got mixed opinions .but nobody ever told us why it would be bad to keep it plugged in.how else would you keep the batteries charged ,also like the fridge on and let the a/c cycle a bit if parked for a while.
- Majja13ExplorerMy WFCO was not performing well so I upgraded to the pd9260 and have not looked back. This unit is awesome it does a proper bulk charge to get the batteries at 90% and then trickles them up to 100%. And then has a built in float to keep them maintained at 100%, however I keep my trailer plugged in when not in use.
- CrabbypattyExplorerThe charge wizard is very important. I just sold my TT of ten years with a pair of Trojan 125's 6 volt flood batteries and they were still going strong. It was a no brainer to do the same set up on our new TT.
