outwestbound
Sep 12, 2017Explorer
GordonThree wrote:
If you have a remote for the Magnum, you can program the charge input current to lesser amps. Off a single blue 2000 watt, I set for 13a and my MS2812 can hit 100 amps charging current into a depleted bank on a cold day.
I recommend saving input current as one of your FAV settings.
mine has a shore power setting to limit what it pulls in. I forgot to reduce this from 30 once and the Honda's breaker tripped and it stopped working.
mine has 10, 15, 20 etc increments and I've used 15 for the Honda and it seems to work without tripping the Honda's breaker.
my AGM batteries need 14.7 for both bulk and absorption, so I just wonder if the magnum's charger gets up to that (it's programmed for these voltage set points) given the Honda's 13.3 amp ac input.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
