outwestbound
Sep 12, 2017Explorer
gatorcq wrote:
By the way, if you set the shore power to 15 Amps, the Mag. will use only about 5 amps of the A/C.
Huh? If plugged into a garage outlet or off a Honda 2000, I've been told to set the shore power down, or the magnum will try to draw too much and blow the breakers at the source. Maybe you could explain this a bit more?
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
