Big_Katuna
Nov 22, 2015Explorer II
I use the millivolt range, then measure voltage drop across every connection. Red lead on the battery terminal post, black on the cable leaving the connector, then keep going down the chain.
You could also connect black to ground and measure each point with the red but most cheapo meters only display a few decimal points.
By using the millivolt range you get more resolution.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
