RJCorazza
Nov 23, 2015Explorer
A 2000w inverter should have a minimum of 1/0 cable to the battery with a short 3' run. With welding cable (flexible) 2/0 and larger is relatively easy to work with, and will allow slightly longer runs.
I have no idea how much heat would be generated at those loads with a x.x volt drop, but I do know the actual voltage drop can be accurately measured and expressed as a percentage.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
