ivbinconned's avatar
ivbinconned
Explorer II
Jan 08, 2022
Will my WFCO 55 amp over charge?
Or can I leave it plugged in all winter as a maintainer?
This is on a 09 Cedar Creek 5th.
  • The WFCO is perfectly fine to float a lead-acid battery in the cold of winter. If still concerned check the battery voltage after a week of no use to see you are in the 13.2 to 13.6 range.
  • Don’t know how well a solar would work here in the frozen short sun lite days of the north.
  • Get a 10 or 15 watt 12v solar maintainer and hook to battery. Disconnect the negative wire and turn off your converter.. Your battery will thank you
  • A thirty watt solar panel with a decent controller will do the job much better. Still need to check battery water level every month however.
Having RV issues? Connect with others who have been in your shoes.24,291 PostsLatest Activity: Jul 30, 2025
