christopherglen
Aug 08, 2015Explorer
150 watts will put 50-80 amp hours a day into the batteries. With the fridge off, you are needing 10-20 amp hours a day for the typical parasitic loads - propane detector, radio memory, some smoke detectors, TV antenna amp. Turn everything you can off - an inverter in standby can pull an amp or more an hour (the larger ones).
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
