MEXICOWANDERER
Nov 21, 2016Explorer
With the power supply ridiculously underpowered to imperil 2 gauge cable and with an intrinsic fuse within a run of 36" of cable can be routed so as to eliminate possibility of corrupting integrity. This is sort of micro hypothesizing failure scenarios is it not? Using common sense is -your- battery to starter motor cable fused? The power supply is utterly protected. The more krap added the more there is to deteriorate and fail. For utter protection of the prposed 2 AWG positive cable, nylon spiral wrap anchored with rubber lined Adel clamps would reduce chance of faults to near zero. Unless of course Freddy Kreuger was to be stuffed into the compartment.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
