racer4's avatar
racer4
Will this work and do I need a fuse? Mean Well power supply
Hi all,
I am planning to install a Mean Well RSP-1500-15 100A power supply about 3 feet from the batteries.
Will this work to fast charge the batteries from 50% SOC to 80% SOC?
Should I install a fuse on the POS+ wire between the Mean Well power supply and the batteries?
More information:
The Mean Well will be used to fast charge the batteries when off grid, with AC power from two Honda EU2000i generators.
Mean Well RSP-1500-15 Specs
I plan to use 1 AWG wire to connect the power supply directly to the batteries. The wires will pass through a sheet metal wall (battery compartment). I will drill holes and install grommets.
The batteries are four Trojan T-125, total 480AH capacity.
A spring wound 2 hour timer switch will connect the power supply to a 20A AC circuit. The trailers power cord will plug into the generator.
The trailer also has a 200W solar panel installed by Cedar Creek.
When plug-in AC power is available, an IOTA 55A converter will be used. The Mean Well is only for when off grid.
The biggest power user is a residential refrigerator, I estimate 150AH use per day through a WFCO 1000W inverter.
Am I on the right track? Will this work?
Is a fuse needed between the power supply and the batteries?
Thanks
Chris
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I did not find specs on the "Power Supply" but I rather like 3-stage converters. I don't like "power Supply" for battery charging.
    As to the fuse.... if the unit does not have an internal fuse YES you need a fuse. fuse is a must.. I mean how else is a 35 dollar Transistor supposed to blow in order to protect a 35 cent fuse.. Only in the 100 amp range it's more like 300 dollar transistor and 30 dollar fuse. :)
  • MrWizard wrote:
    I would be a little concerned about 15v
    12v is not high enough for charging
    And 15v is a bit high, for anything more than few minutes kick in the pants aka equalize
    It's not adjustable it is selectable, meaning you can't get a voltage between the selections
    Maybe Mexicowanderer will see this and give his opinion
    He's are battery expert,
    OP here.
    My apologies, I typed the wrong model number. I edited the Mean Well model number from RSP-1500-25 to RSP-1500-15 (typo), but the link to the specs is the same.
    My understanding is this unit has a potentiometer to adjust the voltage in the range of 13.5V - 16.5V. That's on the 6th line of the specifications. Did I misunderstand? Were you getting 12V and 15V from the first line of the specs?
    I am planning to adjust it to 14.8V. Trojan specs Bulk Charge 14.8V, Absorption 14.1-14.7V.
    Thanks
    Chris
  • I would be a little concerned about 15v
  • Typically I would say a 120 amp fuse is needed close to the battery. I might make an exception for the described conditions. I would double protect the wire through the wall and go with no fuse.
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
