racer4's avatar
racer4
Will this work and do I need a fuse? Mean Well power supply
Hi all,
I am planning to install a Mean Well RSP-1500-15 100A power supply about 3 feet from the batteries.
Will this work to fast charge the batteries from 50% SOC to 80% SOC?
Should I install a fuse on the POS+ wire between the Mean Well power supply and the batteries?
More information:
The Mean Well will be used to fast charge the batteries when off grid, with AC power from two Honda EU2000i generators.
Mean Well RSP-1500-15 Specs
I plan to use 1 AWG wire to connect the power supply directly to the batteries. The wires will pass through a sheet metal wall (battery compartment). I will drill holes and install grommets.
The batteries are four Trojan T-125, total 480AH capacity.
A spring wound 2 hour timer switch will connect the power supply to a 20A AC circuit. The trailers power cord will plug into the generator.
The trailer also has a 200W solar panel installed by Cedar Creek.
When plug-in AC power is available, an IOTA 55A converter will be used. The Mean Well is only for when off grid.
The biggest power user is a residential refrigerator, I estimate 150AH use per day through a WFCO 1000W inverter.
Am I on the right track? Will this work?
Is a fuse needed between the power supply and the batteries?
Thanks
Chris
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 23, 2026
