Acampingwewillg
Sep 15, 2017Explorer II
I should probably start a different Topic for this but here goes....I'm guessing I'm not the only person with a Pusher with a dash air that does not work...I always get a chuckle out of used MH Ads when they emphasize that the dash air works!
Anyways, as I was sitting in the MH today while my brother was over, he says, why not just get the MH air fixed and as usual, I explain that if it were only the rear compressor, I'd do that in a heartbeat but more than likely, it's a leak in one the the lines going to the front condenser.
As I thought this to myself, I wondered if anyone had EVER( in my case, my 10KW generator is up front) put the air conditioning compressor on the generator engine? Now of course I realize that you'd have to have the gen running in order to do this, but it sure would lessen the length of tubing required to replace that run from front to rear not to mention the higher efficiency it would afford. I Know, kinda far out there but what the heck.
