MrWizard
Sep 15, 2017Moderator
i really doubt that there is shaft extenstion
you would have open up the generator housing cut slots, change or add a pulley belt and clutch
why do you think there is a fault/leak in the tubing ?
unless you KNOW you damaged it somehow, that would be last thing suspect
buy some leak detector spray, charge the system with freon
craw under there and spray everything
then you WILL know what is going on
