Claybe's avatar
Claybe
Window Seals
I have a 2004/5 Class C and the Window seals have shrunk and don't fit anylonger. They are coming out at the corners and I can't find anyone who has the exact fit for my RV. A buddy of mine said he took his out, refitted them and used silicone to fill in the gaps at the end. Does anyone know any other ways to repair this?
  • Try www.parkin-acc.com They have many different window parts including seals. It will be easy if you know the maker and model of the window, a bit harder if you don't.
  • If it is the seal I think it is, it just pops out, you can remove it and pop it bsck in leaving the shortage /space at the top of the window.
  • Google RV window glazing bead - lots of info and outfits that sell. Should be some Youtubes on how to install. Here's an outfit that will sell you a sample pack for about $3 http://www.pellandent.com/Motorhome_Product_Details.aspx?ProductID=7377&Return=303
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
