Tiger4x4RV wrote:
I made pop-in panels from Reflectix for all of the windows, even the cab ones. They keep light in or out, provide insulation, and are easily removable. After nearly 500 hundred uses, they are showing a bit of wear around the edges. I'll either tape the edges soon or make new panels.
This is a good option. Works great. Rolls up compact when not in use.
Get the kind of Reflectix that is bubbles between 2 layers of reflective material. There is a thin version but it is not stiff enough to stay in place.
