Muddydogs's avatar
Muddydogs
Windynation solar kit install and performance.
This is for you guys that asked me to report back on the Windynation solar kit. This is the kit I purchased: Solar kit
I just received the kit today which was pretty fast shipping considering the main UPS route between here and CA was washed out in the flooding around Mesquite NV.
I will post some pic in the next few days as I install the components on the trailer but my first impressions of the kit are good. For some reason I thought the wire in the kit would be more flexible then it is so I think I'm going to purchase a 10 ga extension cord tomorrow to use between the solar panels and controller since I will be using the panels in a portable set up until I have more time to do a roof install. I will save the wire from the kit for the roof.
Besides the kit I also purchase this fuse holder to use between the controller and battery as well as an inline ATC fuse holder for the positive solar panel to controller line. For the cabling between controller and battery I'm using a set of 4 ga battery jumper cables I had and battery cable lugs purchased from Windynation.
I will be getting the trailer from storage Thursday after work and starting the install weather permitting although it has to be done by first thing Sunday morning as this is when we pull out.
  • Alright got back from my hunt a few days early but it was a good hunt. The solar worked great and kept the battery's topped off. I did have a problem with the MC4 connectors that came on the solar panel not gripping the cable and allowing the connector guts to pull lose but once I figured that out all was good. The MC4 connectors I ordered separate from Windy nation are fine it's just the 2 on the solar panels.
    I set the panels facing due South and never touched them again. I took morning (around 5 am), afternoon (from 1100 to 100) and night (8 pm) readings to see how they did.
    In the morning my voltage read 12.2 to 12.3 as what I had left after running some lights, radio and heater set on 55 all night. Heater ran 3 to 5 times a night best I could tell.
    Afternoon reading showed 13.0 to 15.0 volts at the battery's with 1.4 to 10 amps coming in under sky's that ranged from mostly cloudy to clear.
    Evening readings showed my battery's at 12.5 to 12.8 volts with a total PV amp's in ranging from 20 amps on the cloudy days to 44 amps on the sunny days.
    I did see a couple amp's in readings of 20 when I checked at different times. I think I was collecting way more solar then I could use.
    I only ran my genny to use the microwave a couple times. I did gang 2 older group 27 battery's in with my 2 group 24 battery's just to make sure I had the juice to keep the heater running if needed. I turned out to be a warmer hunt this year with nightly lows in the low 30's and day temps from 50 to 70.
    As for the portable panels I say to heck with storing them in the trailer, setting them up and trying to not trip on the cord. In the spring I'm putting 400 watts on the roof and forgetting about them.
    Here's some camp pics.
  • Thanks for posting the continued outcome of your solar installation. Nice pictures, too.
    Yeah, you found out early about migrating the panels to the roof, why put up with the headache of moving them in and out. Only those users that are in complete shade cover, continually, or like to tweak and wring out the most amps need the mobility of a movable array.
    You may want to integrate some tilt into your roof-top mounting. I find that it helps with the snow removal in the Winter, when stored. Even after a 6" dump of wet snow, the panel will melt off the snow by the next day.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
