teddychamp
Sep 28, 2013Explorer
You will have to disconnect the two arm that hold the antenna. The arms are connected wit removable pins secured with small lock clips. Make sure you don't loose the small lock clips for the pins. When you pull the arms out of the holders you will see the plastic gear rack. Repair kits can be obtained at most RV Dealers or Internet.
