Want to add a Batwing? to our Winegard antenna. When in the down position it is against the AC shroud so the added wing would not fit. Want to change the down position. Do I change the down position f...
I had a clearance problem with the Wingman and I was told to change the position I had to remove it all and re-install backwards, which wasn't advised. So I opted to put a Jack Antenna on.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
