anchorExplorerJul 19, 2016Winegard AntennaWant to add a Batwing? to our Winegard antenna. When in the down position it is against the AC shroud so the added wing would not fit. Want to change the down position. Do I change the down position f...Show More
wa8yxmExplorer IIIJul 20, 2016You have to turn the mounting plate (Roof) around.. So it's done from topside.Or in many cases you can cut the end director element off the Wingman, Not as good as having all 3, but still better than not having it.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
Related Contentwinegard automatic swm3 antennaWinegard satellite antenna helpWinegard antenna… what’s it good for?winegard antennawinegard antenna
