RJsfishin
Aug 17, 2014Explorer
Manual antenna ??
All my Direct sat receivers have the signal beeper that you can hear a block away. If you have that ......under sat programming, then it is easy to find the 101 sat,.....if like you said, you are pointed near it already. Just move it around until the beeping speeds up, then lock it down when the speed is peaked.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
