- klutchdustExplorer II
Bill.Satellite wrote:
Good job. As long as you were set for SWM you would get no signal no matter what. Getting into multiswitch fixed that. It's OK if you see the message about seven days, it just means it might take that long for the program guide to get fully loaded to 2 weeks of programming. When dealing with this stuff just keep clicking continue until you reach the end where it says "watch DirecTV" and sit back and relax. It sounds like your way worked as well. Just remember that each time you move locations you will need to use slightly different settings.
Bill your way of explaining things really helped as well. I have since gone back into the menu's and looked around which helps in understanding how the
whole things work. Like i told the wife, better to learn now then when we are boon docking in the desert with no phone reception and no one to
ask for help.
see you guys on the road.... - Bill_SatelliteExplorer IIGood job. As long as you were set for SWM you would get no signal no matter what. Getting into multiswitch fixed that. It's OK if you see the message about seven days, it just means it might take that long for the program guide to get fully loaded to 2 weeks of programming. When dealing with this stuff just keep clicking continue until you reach the end where it says "watch DirecTV" and sit back and relax. It sounds like your way worked as well. Just remember that each time you move locations you will need to use slightly different settings.
- CT_WANDERERExplorerGood Going! It get easier the more time you set up. Good Luck when on the road.
- klutchdustExplorer IIHappy to report I have direct tv working. After I switched out the box with the new box i activated last night the set up process went
smoothly. I shut everything off and when I turned it back on all was in working order. The box I changed out this morning was very hot
on the bottom, not warm, too hot to hold in your hand. That is going back to DT soon. Dear wife asked me if I was going to write down any notes,
after the past two days i think Im good.
To all that chimed in with suggestions I thank you.
See you on the road.............. - klutchdustExplorer IIYES! I moved the MH this morning and went on the roof with the compass on my phone, set the direction at 138 + - and changed the dish setting to
18" and SWM to multiswitch ( Thanks Bill!!) the signal strength meter started ticking off numbers, first one was 88 ,and so on. i turned the dish from inside and the numbers
changed ,even had some 100. Anyway I clicked on done. It went to a screen saying the programming would have to load, up to seven days worth. I clicked
off the box and started over. What I noticed is i had to reset the dish selection and the multiswitch option again. Then the signal meter started clicking
good numbers again, it is presently loading the programming data.
Do I need to click or select an option to lock onto the dish selection and multiswitch selection or is that done each time.
regards, - PaulJ2ExplorerAccording to my info Orange is: Elevation 43 and azmith 137.
What I do is check with a compass to get that general azmith direction (137)to point it to. The fact that you get the 775 thing means you are getting something, just not enough to operate it properly yet. As said, go to the on screen menu, listen for the beeps and when they speed up to maximum you are there. Usually 70 to 80% is fine. Thats how I do mine.
Yes it is frustating and I have cussed many times getting it right. When you get the speeding up beeps just v-e-r-y slowly move it a tiny bit up or down or sideways to get the best percentage signal. Hope this helps. - klutchdustExplorer IIThanks guys, when I go to satellite settings I don't get a beep nor can i find the color bar that is mentioned in some posts and other research i have done.
I activated a different DT box last night, I am going to use that today AND move the MH to a different location. Thank you for your patience and input. - CT_WANDERERExplorerA question to the OP. Do you have HD Sat or SD at home? It looks like you are in California general aiming for the Sat101 would be south-east rom your location. Turn on your sat box. Try swing your dish in the SW direction. Watch the sat meter or if your box beeps, swing until you get a rapid beeping. You may have to swing the dish a few time and raise or lower the dish as you swing it until it locks onto the sat. Then fine turn your dish. We travel around the country and I just do a quick swing with my dish and lock in the sat in just a few minutes. It is basically either aiming to SW or SE. Then its getting the right elevation Gary
- Bill_SatelliteExplorer IIYou will not use the tilt or skew setting with a manual roof mounted antenna. You will need to set the receiver to 18" round, multiswitch and then use the settings option in your receiver where you can enter a zip code to get the proper elevation and azimuth.
- klutchdustExplorer IIWell at this point I am pretty lost. What you said makes sense. One thing I noticed is the H24 box is so hot on the bottom you cannot touch it. I am going to activate the new box
that was sent the other day for the spare bedroom and try that. Possibly even though the location looks clear maybe that tree is in the way. IDK. What exactly is the tilt and how would
I measure that, i understand azimuth and height. Can you get HD TV in an RV ?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
