SoundGuy
Nov 06, 2018Explorer
Rmabus wrote:
I have a 2017 Forest River Micro Light that came with the Rayzer Z1 tv antenna. I have not really been able to pick up tv signal with it. Others around with differnet campers/antenna's are picking up channels. I know my booster is on.
You don't have a "booster" - that wall plate itself has no ability to amplify the signal. What it does do is allow switching between a cable input & the antenna and when set to antenna also routes 12vdc to the antenna head which is where any signal amplification occurs. So - have you switched this wall plate from cable to antenna? If so, have you run a scan on your television? Yes, you could add additional signal amplification by replacing that passive wall plate with a Winegard SensarPro which will offer 10 db of signal amplification or 10 db of attenuation.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
