fpresto
May 08, 2018Explorer
The numbers on mine generally agree with Bill's. As he said some play is normal and also correct that you have 3 LNBs in one unit. Another possibility is that the arm is slightly bent. The LNB as well as a new dish are relatively cheap. I am assuming that you have checked the connections and that they are clean and fully seated at the base.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
