What ??
Are you making a problem where there is none ??
I just tried mine,...the elevation crank is supposed to turn while turning the directional pointer. The whole assy turn together. Where is the problem ??
yankee camper wrote:
My Wingard antenna crank handle is all of a sudden is turning when I adjust the directional bezel? It won't turn if I hold the handle. I haven't had a chance to investigate the cause as of yet but does anyone have a tip as to where to look first? Also I got up on the roof and lubed it in May prior to the start of the season.
