SoundGuy
Nov 20, 2015Explorer
BFL13 wrote:
Usually the leak is when the rubber "boot" over the hole the coax goes down (up on the roof by the antenna base) comes loose and rides up the coax, leaving the hole open.
You use some goop and put the boot back over the hole until it comes loose again. :)
The Sensar can also leak if the rubber quad isn't lubricated and becomes dry & brittle ... instructions on how to do this are contained in the Winegard Sensar Owner's Manual.
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Aug 08, 2019
