Old-Biscuit
Nov 20, 2015Explorer III
BFL13 wrote:
Usually the leak is when the rubber "boot" over the hole the coax goes down (up on the roof by the antenna base) comes loose and rides up the coax, leaving the hole open.
You use some goop and put the boot back over the hole until it comes loose again. :)
YEP.........seen this several times
Boot is pulled up on cable and then water tracks straight down coax and drips from crank handle
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Aug 08, 2019
