dougrainer
Nov 23, 2017Nomad
You can get them from a Jayco dealer or a Winne dealer. Both use the solid metal rod extension. They come in different lengths. By going to Winne with your Model/Serial number you will get the correct length for your unit. What is wrong with yours? Unless they are bent, there is usually no other thing that can be wrong. Doug
The Valves are all the same. 1.5 or 3 inch. WHICH part(rod or valve) do you need? The valves can be purchased almost anywhere.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
