keisamcasco's avatar
keisamcasco
Winnebago Vista
I recently purchased a new 2012 Winnebago Vista 26P. I have only driven 500 miles but have noticed what seems to be steering wander. Will an aftermarket steering stabilized offer an improvement over the stock suspension? Any opinions?
    Might want to post this on the Winnebago Owners website
    http://www.irv2.com/forums/f101/
  • Also might check weights on each tire to see if your loading her too tail heavy. Are you towing anything with her? or have one of those platforms with stuff loaded on the tail of your MH?
  • Do as above on tire pressure and if still a problem have a front end alignment before you spend money on "add on's"
  • rr2254545 wrote:
    My Ford chassis Winnebago drove fine, I think you need to check the air in the tires first
    X2, mine drives straight as an arrow.
  • My Ford chassis Winnebago drove fine, I think you need to check the air in the tires first
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
