- anon125Explorergreat idea!
- wa8yxmExplorer III
anon125 wrote:
is there pressure in this little tank?
No pressure, but you may wish to stick a pin in that bag to make a small hole as there could be vacuum.
Two suggestions.. Try assorted caps you may have lying about, (Do not forget a tiny hole, 1/8 inch or smaller) Try spray can caps and such as a temp fix.. once you find the proper size cap visit an auto parts store they may have the cap on the "HELP" display. They are often the same size. - anon125Explorerthanks Hitech
- HiTechExplorerGood question. A pin hole in the bag would not let much dirt in and would answer the question.
Jim - anon125Explorerthanks all
- anon125Explorerjust a thought... is there supposed to be a hole in the top to let in air?
we just have a platic bag held on by rubber bands.
when we use the washer i think there might be a vaccuum in the container.
thanks all - Airstreamer67ExplorerIt means, the above response Times 2, or, Me Too.
- anon125Explorer
subcamper wrote:
Iraqvet05 wrote:
You might check an auto supply store also. Many carry standard sized caps under the Dorman or Help brand name.
X2
Steve
what does X2 mean? - subcamperExplorer II
X2
Steve - anon125Explorerthanks all
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 18, 2026
