wa8yxm wrote:
swimmer_spe wrote:
First, I installed a Tee to allow me to connect the antifreeze to the pump. I use antifreeze as it is best for up here.
That went well, after I waited till the fresh water tank drained.
Uh, no, that is never the best. I don't care if the weather where you winter hits -40 (F or C) or colder Antifreeze is never the best.
AIR is the best.   IF the air ever freezes trust me when I say you WILL NOT  be worried about your RV (though this is intended to be a bit funny. the fact is not for if air freezes...You will also not be alive).
Here in the north, where we get -40C temps, all the trailer shops recommend antifreeze. In fact, if you buy new and don't use antifreeze and have a pipe burst, your warranty is void.
