Canadian_Rainbi
Sep 22, 2013Explorer
Make sure there is antifreeze in the pump too. There should be assuming that you drew the antifreeze into the system using the pump.
Do you have an ice maker in the fridge? Or a separate water faucet at the sink for drinking water that has its own water filter? if so remove the filter and replace it in the spring. Blow out the lines.
By the way, there are no stupid questions on this forum except the ones you should have asked but didn't. There are however, sometimes stupid answers. You'll have to sort those out yourself! :h
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
