grampscamper's avatar
grampscamper
Winterizing question
I winterized my 5th first by blowing out the water with my compressor then drawing antifreeze through all the lines. I've done the same thing for the last 4 years without issue. I spoke to a couple of friends on the weekend that said they leave all their taps open after running the antifreeze through the lines. I've never left taps open over the winter. Is it a good idea to open all the valves? Is it possible to get enough expansion with antifreeze to cause a problem?
  • My opinion is that the pink stuff has some lubricating qualities, and is better for all the faucets and valves than just leaving them blown out and dry for the winter.
    Brian
  • tenbear wrote:
    I have always left my taps closed and have never had a problem. I think that this is one of those things that if you feel better with your taps open, then open your taps. If you feel better with them closed, then close them. If you can't decide, then open some and close some.
    Maybe if I can't decide I could leave them 1/2 open.:)
  • DutchmenSport wrote:
    The "pink stuff" antifreeze does not expand. It's "freeze point" is well below 32 degrees (F). And when it does freeze, it does not expand, it just jells up (gets slushy), but does not expand. If it did, it would be a disaster for us RV owners!
    If you use the "pink" you do not need to leave your valves open. I never have. If you "blow" only, then you may want to leave your faucets open, so there is no risk of water droplets freezing in the tiniest of spaces. But I don't think this is necessary either.
    I've always kept my sewer blade valves closed with "pink stuff" in the tanks. The purpose for this is to displace any water that might be left in the tank, and also to keep the blade valves wet so they do not dry out. I also keep the cap on the end of the pipe to keep birds from building a nest in there and to keep critters out (like chipmunks, squirrels, and bugs in the Spring before de-winterizing).
    Thanks for your reply. I think I was needlessly worried. I haven't had an issue so far and I never leave taps open.
  • I have always left my taps closed and have never had a problem. I think that this is one of those things that if you feel better with your taps open, then open your taps. If you feel better with them closed, then close them. If you can't decide, then open some and close some.
  • The "pink stuff" antifreeze does not expand. It's "freeze point" is well below 32 degrees (F). And when it does freeze, it does not expand, it just jells up (gets slushy), but does not expand. If it did, it would be a disaster for us RV owners!
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
