grizzzman wrote:
If the converter is outputting 14.6 then with the voltage drop "correctly" delt with would not the voltage at the battery be at least close to 14.6?
75 amps through #6 wire is 0.914 volts drop. Frame ground might be a bit better but you also have connections that add a bit. So with so 0.7 drop in the circuit the supply will be 14.6 and the load (battery) is 13.9 volts. 15 minutes later the Boondocker is at 13.6 volts.
#4 shows 0.575 drop so maybe 14.2 on the battery before that timer starts.
Now try 35 amp version....
0.427 drop with #6 and 0.268 drop with #4. This gives more time at a higher voltage and you end up at a higher state of charge before the voltage kicks down.
http://www.genuinedealz.com/voltage-drop-calculatorMember BFL13 ran these tests constantly and posted graphs all the time. I did similar testing to get my WFCO-55 into boost mode. I ended up with about 20' of #2 into four GC2 and it was still hit or miss to get the voltage low enough for long enough to trigger boost.
(credit to BFL13)
