I just replaced a dimmer switch in my truck camper. I used wire nuts to connect the wires. Now I am starting to think I should have used "automotive" type connectors. Any experience or thoughts? W...
Wire nuts work fine as long as they are sized properly. Just hold the wires in one hand and give a good pull on the wire nut with the other hand and if you can't pull it off it's good to go.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
