brholt
Jul 17, 2013Explorer II
Wire nuts?
I just replaced a dimmer switch in my truck camper. I used wire nuts to connect the wires. Now I am starting to think I should have used "automotive" type connectors. Any experience or thoughts? W...
Lynnmor wrote:popeyemth wrote:
Don't forget to twist the wires together TIGHT before you put the wire nut on
You are not to twist together before inserting into the wire nut. If using a combination of solid and stranded wire, put the stranded about 1/16" ahead of the solid.
