brholtExplorer IIJul 17, 2013Wire nuts?I just replaced a dimmer switch in my truck camper. I used wire nuts to connect the wires. Now I am starting to think I should have used "automotive" type connectors. Any experience or thoughts? W...Show More
beemerphile1ExplorerJul 18, 2013Code used to require a sound mechanical connection before applying the nut. That meant twisting the wires first. No longer necessary.Wire nuts are fine if the correct size and installation.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
Related ContentFleetwood Angler wiring2005 SixPac D850 WiringBad tail light wiring12V Electrical wiring - wire nuts vs crimp connectionsWire Nuts (factory) vs splice
