According to the chart I am looking at 12 gauge AWG has cross section 3.31 mm squared and 9 gauge has area 6.63. Will two strands of 12 gauge between solar panels and controller carry the load equal...
You can do it, but the wire connections have to be perfect. The wire lengths also have to be exactly the same length.
Parallel feed are done with large power supplies quite often, but if the lengths are not identical one leg will carry much more current. This can result in a failure of the system.
But the best way is to use a single conductor.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 13, 2026
