cruz-in's avatar
cruz-in
Wire Size to Connect 2 12V Batteries?
Hi Team,
Was helping a friend clean their battery terminals and noticed her two 12 Volt batteries were paralleled with about 12 gauge wire. Seemed small to me. The coach power/ground wires are 6 gauge.
I would appreciate your input in
1) Is this a hazard?
2) What is the proper size wire for connecting two 12 volt batteries?
Thanks
Dan
  • Wire size is determined my amperage rating. If the battery is capable of producing XX amps then you need XXX wire gage. Typically I would go no less than 8ga wire. But ideal welding cable would be perfect
  • The wires need to carry 1/2 the current being pulled from both batteries. It is probably ok, but why not at least 6-8 ga for the interconnect
