suprz
May 06, 2019Explorer
Wire size?
Just making sure, low power LED strip less than 5ft, and the power wire is less than 3ft long. Can I use 20 gauge wire for the 12 volt power and ground? I don't believe the LEDs will draw more tha...
suprz wrote:At the point that you connect the #20 wire to the positive battery supply.time2roll wrote:On the power IN, or the power out?
s/b fine. Consider a 5 amp fuse on the branch circuit.
