Is it possible to put two prong connectors on tail, break and directional lights in trunk of car on a dolly that I can unplug and plug into connectors run from MH plug. Ford Fusion.
You would need to install diodes. You could look for the main connector, go to auto salvage yard and get the connector and wire it in. You would then disconnect from Fusion front harness, plug in wiring from tow dolly.
