wa8yxm
Feb 08, 2020Explorer III
Odds are the breaker is already wired to the outlet when you buy it
White wire goes to sliver-ish screw if not silverish bus bar then the outlet
Black wire to breaker, black jumper to copper screw on outlet
Green or bare goes to green or ground screw.
Depending on the size of the feed line (if bigger than 10 ga, say 8ga) you might want to UPgrade the garage breaker one size so it will not trip. or not. your choice. or put in a "slow to trip" breaker in the garage
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
