joelyn
Feb 08, 2020Explorer
azrving wrote:
There are pictures of the wiring in the Amazon reviews. Your existing pvc/wire will enter the bottom of the box. Black goes to the breaker then it goes to the plug. White goes to the neutral lug and then to the plug. Green goes to the ground lug of the box then to the plug.
Right now your black wire is going to the plug. Your wire is going to the plug and your green ground is going to the plug and to the box itself. The only thing different in the new box is that the black wire will be going to the breaker then on to the plug.
Don’t count on all of the reviews as being accurate and some are dangerous. One guy suggested saving money on wire by not running a ground to the box and driving a ground rod for grounding. This is very dangerous advice.
Again, right now your wiring should be black from your existing breaker to your plug. White from your panels neutral lugs and ground from the ground lug bar. Your service panel where everything starts should be bonded which means that the neutral and ground are connected together. If you were to run any 240 volt “sub” panels off your main service they would NOT be bonded so they would run four wires. You are simply running a 120 volt circuit out to your rv, its not a sub panel. Its no different than any other wall plug in your house other than it’s heavier gauge and you are now going to be able to interrupt the black wire.
Just checked again and now I see the picture in one of the reviews. as u said it looks all prewired which is good. when I get it hopefully should be pretty self explanatory (I hope, lol) and as you said... as suggested if I have any questions I will post a picture and ask..
As suggested in another post a couple weeks ago I did buy the progressive ind. protector so if any problem I would think that would trip even before the breaker or not even allow electric through and give me a code. And AZRVING, I also am from AZ pretty much not to far from you in BHC.....
Thanks again to all of you and as usual I came to the right place to get the answers.. If any other questions will post and give ya'll a follow up once the job is complete.
THANKS AGAIN AND ALL STAY SAFE...
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
