westernrvparkow
Feb 08, 2020Explorer
MFL wrote:Breakers are not intended to be switches. The physical damage caused by normal plugging and unplugging is what usually ruins a receptical over time. Do you turn off breakers every time you plug something in at home? Unless you unplugged the rig with everything on there won't be a big load to cause arcing when you plug it in. Breaker on or off isn't something I lose any sleep over.Lynnmor wrote:westernrvparkowner wrote:
It really doesn't hurt anything to just plug in your RV without switching off any breakers.
Of course the manufacturer put a label right next to the outlet telling you to turn off before connecting. Why would they do that? Maybe they understand that the arcing will damage the contacts, like found in nearly all campgrounds.
I don't understand a park owner saying "doesn't hurt", as he will be paying for pedestal component up keep, as well as having to listen to customer complaints concerning the burnt, or worn receptacles.
Jerry
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
